Clears nicely with fast ratio steering, Not sure yet, but i also think that will also clear with stock small block starter.
Not clear so nicely with original steering box, engine will need to sit quite high, tight fit with that. Mine milodon pan is bit over k-frame level
And goes basically attached to torsion bars. So i decided to heat and bent my headers i bit, also swap V-band flanges to them.
Got only bit crappy pics online, drivers side header is allreay bent in that final pic, think that wiĺl need to bent back bit closer to torsion bar to make starter fit. And passenger side hasn´t been bent, itś loose on that pic.
I mounted my engine about 1,5" right from centerline
