Dead End Kid
I want to get on with putting disc brake/LBP put on the B'cuda, and am going the FMJ spindle route. The only thing I've got to deceide on is how to deal with the requisite late model upper ball joint. I've looked at the Dr Diff E-Bay offering, but it is unclear on how this actually works. It consists of tappered bushings and a "special" gland nut. I can't tell from the picture on how this actually works. Does the tappered bushing actually require them to be welded in place or? The little blurb in the ad, as I remember, sounds like you also actually utilize a lower ball joint. Maybe it is straight forward and I'm just over-analizing it. If cutting/welding/machining is required, I'll probably go the after-market a-arm route.
