66340SEDAN
FABO Member #3649
Excuse me sir... I believe you owe us some pictures of them on the car!
Yep, here ya go!!
I went in to my work today and mounted them up, glad to see the rims are straight and took very little weight to balance out. They are a little taller than the other tires, (both 255/60 15's, 15x6 rims), but seem to fit great! Took it out for a test drive, no rubbing, and man, these things hook good!! They still sping a lot in first but I also didn't heat them up too much, also, the air pressure is at 32psi, lower than and it will be better. I notice it most when banging through the gears, they don't spin as much into fourth gear and man, this sucker pulls hard when it gets traction!! :toothy10::toothy10:
