furyus2
O.K. I made the mistake of putting a TCI valve body in my trans. The problem is, if I adjust the throttle pressure to where the throttle lever is all the way to the rear, I get no kick down to a lower gear. Also, it seems like the throttle lever on the trans moves about 1/3 of the movement before you feel any of the light spring pressure that the lever has with all linkage unhooked.. This makes me think that it's causing the throttle pressure to engage too late, causing the trans to shift too soon. Does this make sense? should I get another valve body? The trans was rebuilt at the time the valve body was installed. Any thoughts? Thanks. By the way, it does down shift to first when coming to a stop.
