drilling magnum heads
We have a mill and a lathe and were thinking of building a fixture. I'll try this first and see how we do. Thanks for the update!
You can't use the dual pattern manifold. It wants to start the bolt holes a little bit low. However I did find that the metal 318 intake gasket makes a great template.
Also if you have a broken bolt in a magnum bolt hole you can grind it flat and then drill the LA bolt hole. You don't need to remove the broken bolt.
I used a c-clamp to hold the fixture where the end bolt was broken.
bumping as I’d like to get on the list for the jig. Does cornernfool have it currently or has it traded hands more since him? Thanks.
watching to see how this pans out.
Guys, I thought these had been found and shipped home. Now I feel like a D**K sending these to the douche. Somehow I fell out of the loop until today. Sorry.
