I'd go 3.23 with that tall of tire. I also don't think mini tubs will clear that big of tire..
ya, I will be fully tubbing it
Turbo, although ideal is a fab it yourself deal and room/space is an issue.
You can get a bolt on procharger setup that will make 750-1000 HP and be very streetable. That is the direction i'd head...
I am planning to run 93 with maybe some mix of race in it once in a while, I Plan on doing the power tours and dragweeks.8.1 will work but you're leaving a lot on the table.
You will make more horsepower per lb of boost than you will per point of compression. An all out race car may run very low compression and a very high amount of boost because they are not worried about throttle response with everyday driving. Since you are building a street car you want to move the compression up so it's not such a dog but not so much that you can't run very much boost without adding higher octane fuel.
I've found that a nice area to stay around for a street car is close to 9 to 1 compression. You can play with calculators computing your "Dynamic" compression ratio with expected compression ratio and boost to find where you are happy running on 93 octane. You need to decide how much power you will be happy with on the street on 93 octane vs at the track on race fuel.
Horsepower with engine size and turbos. You can make way more power than you need to run 9s on a smallblock with single or twin turbos. For instance. Let's say you build a 9-1 compression 360. This is a pretty simple motor but you've put good forged parts in it. With decent heads this motor should make around 300 rwhp. Now let's add a little science. Atmospheric pressure is 14.7 lbs. So for every 14.7 lbs of "boost" you are adding one atmospheric pressure. I usually round it to 15lbs to make the numbers easy. Take your 300rwhp 360 motor and add 15lbs of boost. You have now doubled the output and are close to 600rwhp. This is enough power to push a 3200lb car into the 10.teen range at around 130mph. All on 93 octane. If you change to a higher octane fuel for racing and run the boost up to around 20lbs let's look at the numbers. Engine makes 300 rwhp. 15lbs of boost adds 300rwhp so you're adding roughly 20hp per lb of boost. With 20lbs you would be adding 400rwhp to your original 300 NA RWHP so you'd be at 700rwhp. That's easily enough for a mid 9 second pass.
If you build a 9-1 compression 360 based 408 and make around 400rwhp NA you can run the numbers and see you will be easily in the low 9s around 145mph on 15lbs of boost and pump gas.
Turbos: You're turbo sizing is completely dependent on your motor choice and horsepower goals. There are common turbos that people run but even if you pick a size each size will have several variations. Depending on what you are putting this in you may end up running a single simply to make it fit. At the end of the day what you are looking for is CFM. Your motor will require a certain CFM to run NA. You are attempting to increase that so you need a turbo that will push the required CFM at a boost level it is happy with. You need to look at compressor maps and pick a turbo that will suit your build.
Gearing - Don't run such a high gear that the car is sluggish. Turbos do like long pulls but they also like rpm. Figure out how much power you're going to make. Calculate what your trap speed will be. Pick a gear that put's you just under redline on the tire you will be running for the target trap speed. Autos and turbos are made for each other.
You have a lot of research to do but it's not rocket science. I hope I've been able to shed some light on it for you
The car is a 1968 dart 2 door hardtop- fiberglass fenders,hood,bumpers.
I am planning on a 400 base block and then put a 440 crank to make it 451 and hopefully get about 750-800 hp at the rear wheels. hope to go mid nines, maybe even low eights in the quarter. with the single s480 turbo.
The car is going to have no inner fenders, its going to have a cage that goes up to the front for coil overs.
Thanks for your help
here is what I am aiming for--- goes high eights with a 500 inch stroker and a single s480 turbo. :blob: car weighs 3,300 pounds with him in it, and has 4.30s in it, ya I know , high gears....
I would but I think the pro chargers are ugly, I want it to look good and fast , that hemi would do it nice but,...... about 20k over my budget
Your dad has no idea of what he is talking about. Turbos love highway gears. You have to downshift to get rpms up with a supercharger to make boost. A turbo just needs to be loaded. Low rpm drop throttle and will rip the tires off on the street. Just do a little research on U tube. A turbo is the ultimate variable displacement engine. Low boost drives normal and does not use any extra fuel. Superchargers always use extra fuel
And just what kind of budget does a 12 year old have?
