Dart 72 Member Joined Oct 25, 2021 Messages 21 Reaction score 9 Location ontario Nov 25, 2023 #1 Good day Question, the drive line centre line is offset to passenger side on A body , Does any one know how much
George Jets 1967 Dart 2 Door FABO Gold Member Joined Jan 18, 2019 Messages 9,921 Reaction score 14,362 Location Farmington MN Nov 25, 2023 #2 Can measure the flange hanging down at the rocker panel to the center of the trans tail shaft slip yoke for the left and right sides. Centerline would be overall length from rocker to rocker divided by 2. ☆☆☆☆☆
Dart 72 Member Joined Oct 25, 2021 Messages 21 Reaction score 9 Location ontario Nov 25, 2023 #3 Thanks for the reply I will give it a try now the 383 is in with ear mounts it needs to move over so maybe the tail stock not be accurate, I will measure to the differential instead you think
33IMP Well-Known Member Joined Jul 3, 2020 Messages 5,212 Reaction score 6,355 Location Taxifornia, soon 2b arizona Nov 25, 2023 #4 Depending on which rearend you have, pinion might be offset too. I'd measure at the trans tailshaft, as above.
Daves69 Well-Known Member Joined Feb 20, 2011 Messages 7,532 Reaction score 6,273 Location WestOfChi Nov 25, 2023 #5 .............. Footnote #39
Dart 72 Member Joined Oct 25, 2021 Messages 21 Reaction score 9 Location ontario Nov 25, 2023 #6 Give it ago Thanks for replying
HemiSSDart Dartus Interuptus Joined Feb 20, 2013 Messages 3,188 Reaction score 3,156 Location Illinoisy Nov 25, 2023 #7 3" on a B-Body, I think it was 2-1/2" on an 67-76 A-Body no matter what engine/trans...
