ThanksYes, same driveshaft.
I'm using a 904 transmission for a v8Post 4 is correct. If you use a V8 904 transmission, you can use the same drive shaft. As stated, the slant 6 transmission will not work on the 318. You will need to find a V8 904 in order to retain the same drive shaft.
Your same driver should fit and work fine.I'm using a 904 transmission for a v8
