340(2)1fresh 500 hp on dyno x block new brodix b1ba heads manley valves crower mech cam lifters springs retainers push rods harland sharp rockers msd dist and box jeff johnston v covers milidon pan oil cooler with lines 90 degree adaptor11 qt system aed carb air gap manifold holley 150 blue pump be cool aluminum rad with aux electric fan 8 blade water pump billet pulleys solid motor mounts 8 bolt flanged crank new hemi flywheel mini starter mini alt hayes clutch and pressure plate 833 trams with pistol grip all arp hardware TTI 2 step headers with collectors 1 69 block and steel crand needs machining #3 spun std rods spare brobix heads not new titanium valves 685 roller cam set up 3 sets of j heads ss valves ect 4 torque flites 10 converter aluminum rad spare 22inch stock rad 3 8 3/4 housings 1 489 3rd member with posi unit and axles for all 1 9 inch narrowed with aluminum 3 rd member mark williams 543 gears 5/8 stud axles calipers rotors pads wheelie bars 1 dana srt 10 ram 456 gears 2 360 engines 1 fresh 4 inch stroke h beams 100 over sonic tested to 200 over 1 needs machining 1 383 (66) NICE NEEDS FRESHEN UP 1 440 (78) RAN WHEN PULLED LOTS OF MISC PULLEYS MANIFOLDS e c t 15 YEAR COLLECTION OF MOPAR PARTS PICK UP ONLY SOUTH WEST FLORIDA PROBUBLY 10 CARBS AND ADDITIONAL MANIFOLDS WOULD TRADE FOR A NEW ELECTRIC SHIFT 175 HP OUTBOARD EITHER BRAND WITH CONTROLS AND SS PROP APPROXIMATELY 15000 DEPENDS ON WHO YOU KNOW
