DesertRat
Leading edge boomer
Took my driveline to the specialty shop for modification to fit my gearvendors/8 1/4" SG drivetrain. Took the GV slip yoke and the bare driveline (spiders removed) and they rebuilt it to 35 1/2" C/C with new front tube yoke and two new HD u-joints installed and dynamically balanced as an assembled driveline. Called me before I got home (90 mile commute with car stops, dealing on a 40 ford pickup) and said it was ready. Turned around and picked it up, got home and installed it in the car! Another step out of the way. Should be a good weekend on the car-going to do the Pertronix conversion and remove the balance resistor and wire the electric choke on the carburator. Will entail re-building the entire right side engine bay harness but it will be worth it. I installed my rebuilt power steering pump and the pully had a 1/4" wobble in it so it went back to the rebuilder for warranty repair. Had to change gears to keep progress moving forward. Off to the exhaust shop soon!!!!!!!
Cheers to all-----------DR------------:coffee2:
