340mopar
Maybe the term bind was to "strong" a word, I should have been more detailed and said
"As you adjust the operating angle of the u-joint (by lifting the vehicle, shimming the rear axle, etc) you are also changing the elliptical path that the u-joint must travel in. The greater the operating angle, the less like a circle the path of the ellipse, and the greater the torsional vibration caused by the u-joint"
But then I would have had to include that this is a qoute from
Driveline Basics with Steve Johnson and I just thought that was to much and said bind instead. My bad.
Real nice, Ace.
Quick to insult and easily offended, even though all I said was that I felt it was odd that a person who claims themselves to be an engineer dosn't understand three simple things in regards to suspensions, demonstrated by how you responded to the post.
Seems like the only troll here, is you. Trolling for a fight, with your insults and implications that someone could not know more than you regarding a subject, just because they choose not to plaster info about themselves all over the internet and because you have a self-rightous, greater than all, attitude because "yeah I'm an engineer". Whatever. Go troll elswhere.
