flathead31coupe
I have a driveshaft with a counter weight at the trans end...can I remove the yoke and turn it around...the weight would be at the rear end...then I can cut the driveshaft to the length needed...
so it wont work.....putting the balancer end at the rear end...66 ish. Hmmmm That is a harmonic balancer. You should be able to eliminate that. I would find a later model shaft to cut.
It would work if you don't have a pinion snubber and have room in the tunnel area to clear it.....so it wont work.....putting the balancer end at the rear end...
Looks like I have the room...so no ill effects using it this way..It would work if you don't have a pinion snubber and have room in the tunnel area to clear it.....
It will make it a bit of a pain to put the strap bolts in...Looks like I have the room...so no ill effects using it this way..
