What would be an approximate % for driveline losses for an automatic and for a manual transmission? That is, difference between rear-wheel HP and HP at the crank.
Thanks!
The weight of the clutch and flywheel in a manual trans can also have a big effect on the power you make at the wheels. The more it weighs the more power you loose. As does the diameter the bigger the clutch the more power you loose.
