Anyone point me to an air cleaner base that give the most hood clearance for this carb?
Jim
Jim
This for the A100 Jim?
You could use just about any drop base, and then pick the thickness of element that gives you clearance and airflow.
Here’s my set up 408 blue print. With 1.5” drop base 750.
Yes I’d like to believe so. Mine is a manual trans.Is there room if one has the Chrysler adapter on the throttle arm?
