drum brakes case wont go back onto the drum brake
When the brake shoes are fully retracted the 1/2 round should be sitting on the upper center post.
The adjuster at the bottom can be fully screwed into itself.
If you still can't get the drum on over the shoes I suspect you have some wrong parts.
The self adjuster is all the way screwed in
The self adjuster is not keyed into the right place on the brake shoe.
It goes into the notch in the bottom of the shoe and not the area where the shoe material is bonded to .
However the bottom spring is on 180 out. It may interfere with the self adjusting arm hitting the spring coils.
are you referring to the black spring on the bottom, and if so is that one supposed to be even across the brake.
Adjuster is on the “shoe” not on the plate. if you remove adjuster and turn notch 90 degrees it will sit where it is supposed to. Tough to see, but its in the right place.
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Exactly!
