Reliability is best w/ later 2-bolt aluminum MC and 2-4 adapter plate. Most use a 1980's Dodge truck MC. Dr Diff packages that for ~$90. Did you try google? Might find him on ebay. I bought adapter plates there ($30). I used MC from 95-99 Breeze w/ ABS in my 64 Valiant. See post w/ photos. Factory brake rod worked fine. If you prefer the rusty cast-iron look, a late 70's Dart MC will work. Best to use silicone fluid with those since the top covers often leak and dribbling glycol removes paint real well.
Drums or disk doesn't matter, other than really old MC's that have a residual valve in the port for drums. A "disk MC" can work fine w/ drums. A manual MC supposedly has a groove in the piston to capture the rubber bushing on the tip of the brake rod. I couldn't get the rod out without destroying a new bushing when I used the "power" Breeze MC, so seems to work regardless. If you plumb in a proportioning valve for later front disks, I think you can still adjust it to work fine with a drum-drum setup. I did so.
