Howard1784
Reversible, 1,800 cfm, Black, Plastic, Each Flex-a-lite Twin-Line electric fans provide maximum airflow--up to 1,800 cfm--but require very little mounting space. They're designed to replace your stock, power-robbing, belt-driven factory fans, where applicable. Twin-Lines feature dual 10 in. fans mounted in a lightweight, one-piece plastic shroud. They are fully reversible and an adjustable temp t stat(180-240 degree F)
1,800 cfm
Dual
10.000 in.
11.250 in.
22.000 in.
4.125 in.
10 blades
2,500 rpm
Plastic
Black
Black
Glass-reinforced nylon
15.00 amps
$100 plus shipping, used for 1 summer and upgraded. (20110 area)
Maximum Fan CFM
1,800 cfm
Fan Quantity
Dual
Fan Diameter (in)
10.000 in.
Height (in)
11.250 in.
Width (in)
22.000 in.
Thickness (in)
4.125 in.
Number of Blades
10 blades
Maximum Fan RPM
2,500 rpm
Blade Material
Plastic
Blade Color
Black
Shroud Color
Black
Shroud Material
Amp Draw
15.00 amps
