[FOR SALE] Dual Electric Fans
Howard1784
Rochester, NY
Used 1 summer and went to a custom set up:
includes Thermostat
$250 or best offer plus shipping from Manassas, Virginia.
Diameter, Reversible, 1,800 cfm, Black, Plastic, Each Flex-a-lite Twin-Line electric fans provide maximum airflow--up to 1,800 cfm--but require very little mounting space. They're designed to replace your stock, power-robbing, belt-driven factory fans, where applicable. Twin-Lines feature dual 10 in. fans mounted in a lightweight, one-piece plastic shroud. They are fully reversible and are available with or without an adjustable (180-240 degree F) thermostat
Maximum Fan CFM
1,800 cfm
Fan Quantity
Dual
Fan Diameter (in)
10.000 in.
Height (in)
11.250 in.
Width (in)
22.000 in.
Thickness (in)
4.125 in.
Number of Blades
10 blades
Maximum Fan RPM
2,500 rpm
Blade Material
Plastic
Blade Color
Black
Shroud Color
Black
Shroud Material
Glass-reinforced nylon
Amp Draw
15.00 amps
Yes, this will fit a stock radiator as shown. Just add the proper tabs for mounting.
It hangs over a fraction of an inch but the metal can be pushed slightly outward and the fan part is flexible and will fit snugly.
