i have a Holley 3310-4. I believe its a 4160 as it has one metering plate and one block... what is a good fuel line that doesn't leak? I'm currently running a stock carter pump with stock metal line on an edelbrock... i really don't want to run any rubber line if possible... i wouldn't mice running a good braided fuel line, but they all have A/N fittings and i believe the stock pump is an npt or pipe thread fitting..
thank for the input
thank for the input
