dual fuel line recommendations for a 4160 Holley
texas360
TEXAS
i have a Holley 3310-4. I believe its a 4160 as it has one metering plate and one block... what is a good fuel line that doesn't leak? I'm currently running a stock carter pump with stock metal line on an edelbrock... i really don't want to run any rubber line if possible... i wouldn't mice running a good braided fuel line, but they all have A/N fittings and i believe the stock pump is an npt or pipe thread fitting..
thank for the input
Summit and it's adjustable.
I made mine out of the earls carb fittings and some aluminum hard line. The length has to be exact if you make it. Took me a couple tries, it shortens up after ya flare it.
but all the big brands make the double feed fuel inlets.
