D dgracing Member Joined Sep 1, 2017 Messages 9 Reaction score 0 Location champlain Oct 7, 2017 #1 hi on my 1974 duster with front drum brakes i want to switch to disque brakes can i use the front brake of a 1977 aspen ?
hemi71x FABO Gold Member FABO Gold Member Joined Dec 22, 2009 Messages 7,711 Reaction score 4,951 Location Rancho Cordova, CA Oct 7, 2017 #2 Ya, everything off the Aspen, & Volare cars, works quite well.
D dgracing Member Joined Sep 1, 2017 Messages 9 Reaction score 0 Location champlain Oct 7, 2017 #3 the spindle also ?
72bluNblu FABO Gold Member FABO Gold Member Joined Nov 28, 2008 Messages 15,104 Reaction score 9,205 Location NorCal Oct 8, 2017 #4 dgracing said: the spindle also ? Click to expand... Yup, everything spindles and out works fine. The UCA’s don’t swap but your ‘74 drum UCA’s should have large ball joints anyway so the FMJ spindles will bolt right up.
D dgracing Member Joined Sep 1, 2017 Messages 9 Reaction score 0 Location champlain Oct 8, 2017 #5 ok good will remove the parts from the aspen and check out the installation on the duster after thanks .
D dgracing Member Joined Sep 1, 2017 Messages 9 Reaction score 0 Location champlain Oct 8, 2017 #6 well that was a easy job the only thing that i have to do is the brake line because now the galiper is in the back , like the aspen was .
