Not a problem, but keep in mind the factory never made 15" small bolt pattern wheels, so you'll be looking at aftermarket wheels.I have a 1972 Duster with factory rear drums and factory disc brakes up front....thinking on using 15'' rims instead of the 14s''....my question is would the brakes be ok running the 15' s ?
Thanks
ok thanks for the follow up...at this time going with crager ss rimsNot a problem, but keep in mind the factory never made 15" small bolt pattern wheels, so you'll be looking at aftermarket wheels.
ok thanks for the follow up,,,Ill check on pattern and get back to youAre they the old small bolt pattern?
Hi...so I measured studs and are 2 3/8 '' apartok thanks for the follow up,,,Ill check on pattern and get back to you
ok makes sense...thanks for the infoLarger diameter wheels will help keep the brakes cooler because of more area for air around the calipers and rotors. 15" a double positive. More tire and wheel selection.
