Got some emblems for the scoops but they don't use a speed nut , they have the plastic inserts , I can probably figure it out but does anyone know the drill bit size off top there head ?
They are the same emblems for either scoops or fenders the only difference is the fasteners. The nuts will fit either emblem. In the past we would use nuts on the 72 - 73 fender emblems when replacing them onto a fender after a collision.May put them on the fenders under duster emblems and get the others for the scoops
Unsure about the reproductions , which are good to use on the scoops ?They are the same emblems for either scoops or fenders the only difference is the fasteners. The nuts will fit either emblem. In the past we would use nuts on the 72 - 73 fender emblems when replacing them onto a fender after a collision.
