pilotsf
- Joined
- Aug 18, 2009
- Messages
- 181
- Reaction score
- 0
Hello again.
You guys are 100 % on all the info you have given me so far ! I have another one.
I just put 10,000 mile on my rebuilt 360e/904t and took it to a dyno and was very bummed when I got the results. I spent 8500.00 on the engine,trans and install(removed blown slant 6). My dyno numbers are 275 hp and 300 lbs Trq. The tester said my Trq was real low and the hp was above average , but my engine is not stock. Can you please tell me how to get the trq up (most important) and then any help about the hp.Or is this a good number? here are my specs
1/4 mile times:13.50-13.70 @ 98-103 mph
Engine
360
bore, 30 over
comp,9-1,9.5-1
cam, 280[at].60 duration 480 lit
air fuel,edelbrock performer rpm manifold and 800cfm edelbrock carb
ignition, orange box mp distributor
headman headers small diameter , and 3 inch strait pipe flowmaster and turn downs
Trans
904
stall ,tci street/strip 1800-2500 breakaway
3.73 gears 28inch tall tire
Please help !!!
Engine
360
bore, 30 over
comp,9-1,9.5-1
Trans
904
Please help !!!
