Now that I have my car running pretty well, I want to see what an expert can do with it. I have never had it on the dyno. My question is how do I prepare for the dyno day? I will be contacting a Dyno tuner in Spokane who specializes in high performance and EFI systems. I am not versed in what to expect.
What should I bring to the Dyno test? It looks like they set aside a day to do it. I do not have a bunch of manifolds or carb spacers to exchange or try so changing parts is not on the agenda. Maybe being a performance shop, they would change the carb spacer but that would be the limit, I think.
What should I ask them about, before and day of?
Should I be there for the whole thing, will they let me, should they allow me to be there? I would like to learn about it.
Any advice on what to expect???
This is where I am now. I have driven the current tune several hundred miles to allow for self tuning of the EFI.
1973 Plymouth Scamp
RB 512ci, 440 source stroker kit with lightweight crankshaft, forged pistons, 10.83 CR. Trick Flow 240 heads, 440 source aluminum rockers 1.5RR, Trick flow single plane intake. Holley super sniper EFI, hyperspark ignition, coil and distributor. TTI 2 inch headers. Hughes 3000 stall converter. 727 transmission with transgo tf2 valve body mods. B&M Quicksilver shifter. Gear vendors overdrive to 8 3/4 rear end with 3.91 gears, braced in back. SS leaf springs. Competition engineering race shocks. Pypes exhaust 3" into 2.5 inch. RacePro mufflers. Cooper cobra 275/60-15 28.2 inch diameter tires. Current cam specs 244/252 @ .050”, 282/290 adv, .516”/.537” lift(1.5:1 rocker), 112 sep, .016”/.018” lash, Solid lifter from Oregon Cams.
Just for fun what power/torque do you think I will have before and after a professional tune??
1973 Plymouth Scamp
