dyno is done and the numbers are in........
There's a 7" high one available - not sure how that compares but I assume the shorter one would be no taller than the EFI intake otherwise why make two different heights?
I'm wishin I hadn't gone with the ModMan now.....
I don't think you'll stand any chance of fitting any variety of the Drag Pak style intake under a stock hood. The stock EFI intake has long runners, but it also sits down between the heads and actually under the intake ports to some degree, so it packs some extra runner length in with clever geometry. The ModMan barely fits under a stock hood unless you have a low profile air cleaner (ask me how I know...). That's probably one of the big reasons carb style intakes have such short runners is to keep them low since you have to stack a carb on top of all of it and still try to make it fit under a hood.
