pettybludart
I used a slide-a-link system from competition engineering and adjustable pinion snubber.Talk about hook I snapped an axel (8 1/4).can,t wait to get the 8 3/4 rearend in.Should lift the wheels up now:cheers:
I don't think lobe centers alone will change much of anything. It's just a mild cam on that package. Not sure what every part is in it, but I'm sure cylinder pressure is not a problem...lol.
Taking out valve train geometry loss (worse with hydraulic rollers than even std LA) and the usual rocker ration errors, that cam is only about .520/.530 lift at the valve. It's not meant to make mad power, just stone reliable and torquey. With plenty of bolt in expansion available. I also agree if getting the most out of the engine is you ultimate goal, a flow test of your heads (not advertised "stage II" from Shady Dell, is the first order of business.
I think we're on the same page, just looking from two different angles...lol.
Exactly!
Neither of you know anything!!!
Both of you go to your rooms... :-D
j/k
Always good to read what people are thinking. Neat to pull nuggets of info out that others think of to explain a difference. As long as it's civil.
Some cam manufacturers specify lift at the cam and lift at the valve and they take into account the lifter angle. Here is the cam I just bought:
http://www.cranecams.com/index.php?show=browseParts&action=partSpec&partNumber=699641&lvl=2&prt=5
D- lol..thanks for the kind words, but there's a few others (at least) here with a lot of good knowledge. Not only do they possess it, they dont mind sharing and aren't Aholes about it. One thing I like about this site in particular is a good atmosphere to toss around ideas and get feedback with respect, regardless of level of question. Being a tech guy other sites, I can safely say other sites are not so blessed.
Moper helped me out with something I totally forgot about with a carb and it really woke up my car.
