VOETOM
For all you that need ultimate performance with minimal sound and especially any that run the FAST classes that can only use 2.5" inlet and outlet mufflers, I found a set of new Dynomax 17289 st. st. mufflers that I have had for while.
They are new, straight through, offset inlet, center outlet with 2.5" inlet and outlet bushings. They are stainless steel and fit right on the B-body chassis. These are the HEMI-sized (20" long body) mufflers and are likely what many of the FAST guys run because they work so very well. With some creativity, they can be made to fit A-Bodies as well.
Today, from Summit or JEGS, new ones are up to around $153 each (total ~$306 pr) with shipping to many places about $15.00 the pair (or total of $321 to get them to you).
I'll sell them both, including shipping, for $255 if in the USA and if shipping does not cost me much over $20 max. I am located in Missouri.
Thank you.
Tom Hand
Thank you.
Tom Hand
