dazedand confused
Did a part 2 video on this . Finally solved the issue I was having with early to mid 60s for the 7-1/4 rear end axle shaft seals . found out though much internet searching and measurements since O'reallys said that the axle seals are not available that the axle seals for a 1965 Ford Falcon 9"rear axle fits the 7-1/4 axles and housing tubes. the only differnt is the width on the metal shell . its a couple of hairs narrower then the Mopar ones . precision bearings & seals part # 9569S I imagine standard seals or Timken has same seals with different part number . hope this helps people .
