Are you asking if a push button shift 904 can be fitted with a later slip yoke type output shaft and extension housing? Probably not, but what would you do about the Park position if it did? I think the main problem trying to do that swap is the rear of the main case. The cable shift transmissions have a rear pump and the slip yoke versions don't. Without machining and re-engineering, they won't just bolt in.
