I'm sure you could sell all your new stuff...Sell it all and buy his HDK front suspension...No headaches...If you havn't seen this stuff up close go check it out..Its top notch.
I sure wish i could have got ahold of you before i bought all new brakes, spindles and started building my own stuff! That's very reasonably priced.
I would love to have one of your kits. I need to save some more change. And as for a test car. I think I could bring some attention to your brand. But you know all to we'll my time frame is always not as close as I would like.
Denny. Let's talk and see if we can work something out. Thanks for the kind words about my shop. Your product is second to none. I was very impressed with your kit. In my opinion it's the best thought out kit you can buy. I install a lot of suspension parts from all kinds of manufacturers. Yours my friend is top notch.
Me too....I don't think most realize until they try it themselves how much goes into it.
As I read this I'm sitting in a furniture store STILL trying to figure out how to make factory spindles work with my setup....while my wife buys a chair ..........
Unfortunately I don't think there's any way you will be able to use unmodifiedI'd be interested if you get the setup modified to use factory spindles.
Will your set up be good for drag racing abuse? I may be intrested. I set my 65 up for a bigblock but will be running a 360 until I get the chassis sorted out.
We will make it happen....
still doing the SRT4?....maybe I need to find a dummy block /trans for motor mount mock-up
I see on your thread you have your wheel / tires mocked up....how far is the hub from the frame rail?.....on my initial mock up, I can get 12-1/4" (12" if I squeeze) and of course can adfust the hub out to 13"plus.
also for the non-HDK aftermarket K-frames with a wider, non-adjustable track width....A builder combined the HDK upper shock mounts / chromoly supports with his non-HDK K-frame (removing the shock mounts on the K) . Then shortened 1" out of each control arm and added a longer shock (using the HDK shock simulators to determine which one was optimum). The wheels /tires tucked in and the suspension wasn't as harsh.
.....let's just say he liked it.
it's Hot Roddin' 101.....make to your liking.
What kind of bellhousing bolt pattern does the SRT-4 motor have?Yes still working with the SRT4 motor.
Denny what measurement are you looking for? My valiant is all together and I can measure what you need. I do have the later 73-76 disc spindles and rotors on mine so that might skew the information some. Oh and I have RMS upper control arms and strut rods.
its a start...I can do a little subtraction and figure out what it should be with the factory spindles and brakes.
simply how far out from the frame rail the hub surface (where the wheel bolts on) is. I need the measurement when the suspension is at ride height.....if the suspension is hanging it will not do much good.
Denny, at ride height I am measuring it at 13" or just a hair under. If you need any other measurements just let me know.
