vitamindart
does anyone know who makes an early A slant six header?
Why hasn't anyone (or has anyone) bothered to do a run of replica Hyperpak headers? I'd love a set for our 64 Dart. I'm in Australia and I'm really stuck for decent manifold choices, all the tube-headers (as you guys call them) make me nervous as to whether they will fit because our car is still left-hand drive. I'll be watching this thread to see what the outcome is.
I thought all the Aussie stuff was 67-up?
Not quite. The first pic is what's called "Dual Dutra Duals", that is two front-3 Dutra castings.
The second and third pic are Dutra Duals: a new Dutra front-3 casting and a cut/capped stock manifold for the rear 3.
Last pic obvs Hyper Pak.
The advantage of the cut-and-capped manifold is that you retain a hot-box which will mate to the Offenhauser intake, giving preheat for cold climates.Make a copy of the Hyperpaks out of Header tubes. Even a muffler shop could make them for you for less than a set of Cliffords. Just give them the Ebay flanges.....Doug said the capped riser side flowed as well as the fronts, although it looks like it wouldnt.
Thanks Dan,
I am aware of them, we swear by their inlet manifolds, and I understand the Americans love them too. For our car I was really after something that looked 'old school', hence I want to run the Offenhauser 2 x 1BBL set up, apparently Summit still sell them. For exhausts my original thoughts were along the lines of an after-market cast header, I researched those and ended up in this discussion about Dutra Duals, Clifford tubular headers, etc, but ideally I was interested in whether anyone was casting replica Hyperpak headers? Apparently someone is keen, but subject to sufficient interest, whoever that somebody may be.Nigel, What about Aussie Speed. They say they make a header that fits the left hand drive
I have a set, here, but haven't tried them yet.
Aussie speed performance manifolds alloy valve covers roller rocker spacers air filters for Holden Ford Valiant Chevrlot V8 V6 and inline 6 cylinder engines Aussiespeed performance shop
Nigel, read this thread, and send Rick a message.
Slant Six Forum, :: View topic - Hyper Pak Exhaust Reproduction
