Early A sway bar
chryslerfat
Monroe,Michigan
As pictured shipped from Monroe Michigan to your door for 150 within the US 250 with a pair of control arms with tabs. Pulled from a 65 Barracuda will fit Dart and Valiant also from 63 to 66
That's a good deal! I've seen just the early A sway bars go on eBay for what you're asking for everything!
Does this fit early a bodies without any modification?
If not Im interested,
thanks
Ok great, Im guessing it installs on those 2 holes right next to the strut bar?
Is the price negotiable? New kits are the same price w all fasteners.
,Cliff
240 is the lowest I would go. Shipping does cost money and the new kits that are available do not fit as well as stock. I have seen the headaches that guys have had trying to mount the aftermarket bars.
Thanks
I will have to pass fet, thanks for the pictures. Spent a lot these last few days, sorry.
Are the sway bushings still available new from any vendor you know of?
The pins and bushings are but I am not sure about the bar mount bushings. I do see some listed on the Autozone website but the mount is different. You may be able to get those to work reusing these mounts.
My 64 had the holes from the factory and yes it would, but some may not be pre drilled?
