[FOR SALE] Early Slant Six parts
Mopar Mechanical Parts For Sale
  1. newmexguy
    newmexguy Well-Known Member
    1,266
    68
    Apr 8, 2009
    Las Cruces New Mexico USA
    Local Time:
    8:01 PM
    Contact Seller
    Early Slant six parts (pre '67)
    Water pump, turns, not heavily oxidized $10
    Oil pump, turns, not heavily oxidized $15
    Water pump pulley, #2202666 fits up through '72, single groove, power nothing $15
    Water pump spacer, aluminum, universal, 1/4 inch thick $5
    Cast iron lower mount $15
    Block to trans brace, $10
    Coil with bracket $10
    Choke pull off rod and base $5
    Throttle rod bracket $10
    Buy it all. $50 Should fit in $22 flat rate box. So $75 shipped 48 states.
    Located Dona Ana NM 88032.
  2. slantsixdan
    slantsixdan =..=
    6,647
    1814
    Jan 7, 2007
    Vancouver BC
    Local Time:
    7:01 PM
    Fits clear on up through however late of a model you've got, if you need a single-groove pulley.
  3. Bigboy 68
    Bigboy 68 it is what it is FABO Gold Member
    1,373
    201
    May 16, 2017
    Newark,Delaware
    Local Time:
    10:01 PM
    Is that an early a alternator bracket I see in the picture that is not listed with the price please let me know thank you I’m looking for one
  4. newmexguy
    1,266
    68
    Apr 8, 2009
    Local Time:
    8:01 PM
    If you mean the item in upper center, yes it is slightly different than the same item in my other late sixties slant grab bag
  5. newmexguy
    1,266
    68
    Apr 8, 2009
    Local Time:
    8:01 PM
    Looked up Pulley # on Ebay, going by Ebay seller's description. Thanks for the clarification. Mine is less than half his price, btw.
