I'm on often enough, but not selling or hunting
I'll be dammed if I can figure out how to post a search for a part
search for a part
Funny, i was assuming he wanted to post a “wanted” thread.assumed you were not wanting to post a Wanted thread of your own
Exactly what he wanted to do. He never got back here to answer us. I see he needed a z bar and he just asked in a general thread. That's a no no in these parts. LOLFunny, i was assuming he wanted to post a “wanted” thread.
Words. Ugh.
Mike, Cars and Mopar Parts WantedI'm on often enough, but not selling or hunting
Go to the search box (upper right) and type in what you are looking for. Now, ig you put "headers" every post that has the word headers in it will be listed. That's how it works. Too bad the software doesn't have an option where you could click on "Marketplace threads only" but the software doesn't allow it. I usually go to forums and then look at the Marketplace forum that would have the item I was looking for.
Are you wanting to place a Wanted ad?
Michael Brisebois
In the search, if you want to string search words together use the + sign between words without spaces
340+headers
You can also check the box that states
∆ Search titles only
You can also select in the drop down whether you want to search
Everywhere
Threads
This Forum
This Thread
If you go to the Advanced search, it allows you to sort results by date and not Relevance (which is the default)
If you use your browser "Back" button you can return to the results to check the next thread.
If you switch from the basic search to the Advanced Search, you'll have to re-enter the criteria again. It doesn't persist
I assumed you were not wanting to post a Wanted thread of your own
Good luck
I have never noticed or used the dropdown for This forum, this thread, etc. I remember it used to be included in the advanced features and disappeared from there with the last software change. My bad.In the search, if you want to string search words together use the + sign between words without spaces
340+headers
Everywhere
Threads
This Forum
This Thread
Good luck
