Got rest of stuff done this morning, then had doctor's appt.....then back to garage.....got it fired up and timing set..,,,,even after all these years....had two plug wire crossed.
Got to love the simple speedmaster distributor set up...two wires....
water pump is leaking a the seal on the end of the pump.....as you can see the water ,,,,,,those old MP cams with their 28/32 lash setting are really noisey.....probably going to tighten it up a few thousands....
