DaveBonds
Garage Trash
If something comes up that you don't like, simply redo the search with a - prefixed to the word that spams your search.
Like 1964 plymouth brakes -pads. That works really well.
I avoid " " because not everyone words things exactly.
This is also why it helps a lot to search by category, rather than the search bar, because your keywords could completely miss an auction that may be of interest to you, listed in the same category.
One good example of that would be a search for Mopar four speed, vs 833 4 spd. or A833 manual.
If you use the search bar, be as vague as you can with words and use a - on keyword hits you don't like, redo the search and you will come up with the most accurate results.
Hope this helps.
Hope this helps.
