I Have this harness on the way. My car takes a 4 pin ecu,this harness has a 5 pins. Which pin do I bypass or ignore for my 78 Cordoba?
http://www.ebay.com/itm/NEW-Chrysle...Parts_Accessories&hash=item4859c53545&vxp=mtr
You are bidding on one NEW genuine Mopar Performance hi-po ECU wiring pigtail. This is the wiring that gives you the correct plug in for the electronic ECU, or spark control box. Replace those points over to a new and improved electronic ignition. All you need is an electronic distributer, ECU / spark control box, and this wiring pigtail. Better spark equals easier starts hot, or cold. Be sure to combine this with my Hi-po ECU also available in my ebay items for sale.
