JR
Pissed off senior member.
So far...
76 360 40 over on the block, 10 mains and 10 rods
a set of the high swirl 80's heads with a real nice port job on bolth intake and exhaust sides and 2.02's.
Cam specs...
CHRY V/8 HYD. CAM
CID/LTR 318-360
SPECS INT EXH
DUR [email protected] 210 220
VALVE LIFT .429 .444
The summit rebuild kit I got was the cheapo sealed power fel-pro kit with
8.66:1 compression (so they say) hyp. pistons.
I can use either a eddy 650 or a BG road demon thats in the same range as the eddy.
For exhaust I am running 360 truck mannafolds into 80 inch long 3 inch sidepipes. I was told that the 82-83 dakota 318 magnum exhaust mannafolds flow better than the 340 mannafolds that people charge an arm and a leg for so I was going to try a pair of those.
Intake......Anyone use a eddy airgap intake on a daily driver? or should I go with a performer, or use the old Offy 360 intake for a smallblock that I have on the shelf?
Cam specs...
CHRY V/8 HYD. CAM
CID/LTR 318-360
SPECS INT EXH
