straightlinespeed
Sometimes I pretend to be normal
Edelbrock 1405 600cfm carb with electric choke. Basically a 1406 carb. Thought I had a problem with this carb, so I ended up picking up a different one. Ended up being a bad cylinder with broken piston rings causing all my issues.
I wont be needing this carb any longer, and would rather send it to a good home, than let it collect dust and get damaged. The metering rods have also been changed. Sorry Im not sure what to though. I can open it up and find out for you if its important. $150 plus shipping
