fine tuning the carb I found the driver side air/fuel adjustment will not cause the idle roll off when turned in all the way. left side turned in will kill the car. less than 100 miles on the carb, new filter always. dual plane eddy performer. tried to find an air leak spraying fluid around base and intake, nothing.
any ideas? I have a new gasket to try next. just runs too good to tear apart :burnout:
