Optik
Need help with what I think is a carb issue? I'm running a '77 360 with a stock bottom end and heads, Holley Street Dominator intake, headers, somewhat lumpy can (233 @ .050, .512 lift), and an edelbrock 600 model 1406 carb in a 64 Dart with built A999 and 2.93 geared 8 3/4. Car has a nasty hesitation/stumble when I'm barely on the throttle at takeoff or cruise. Goes away when you give it more gas. I believe I have the timing correct, car seems to like about 18* initial with about 34* all in by 3000rpm. Ran fine for almost 20000 miles but has developed this issue recently. I've been able to affect it somewhat with idle mixture and slight timing adjustments but cannot tune it out completely. Have not yet taken the carb apart and my next step will be to pull and try to read the plugs. Anyone have any advice or experiencing similar issue?
Thanks,
-Tim
Thanks,
-Tim
