[FOR SALE] Edelbrock D-64 dual quad dual plane
str12-340
Vashon, WA
This manifold is originally designed for early (64-5) 273 heads. It will work on 66 and up heads with 8 degree tapered washers and a bit of work on the bolt holes (a very little bit). This and the 66 and up D-66 are the only dual plane, dual quad intake made for LA motors. Some on FABO claim successful use on a 340 or 360, but these have the 273-318 small ports so I don't know. Looking for $400 plus the ride from Seattle Area.
View attachment 1715611957 View attachment 1715611958
There is an issue with the size of the area around the small ports, bit it is true that you could get a lot closer to the bigeer port heads. Of course better for a little opening from intake to head, as compared to a tightening at the same point. I specifically wanted small port heads for my current project as a boon to gas mileage and low end torque, but it's not like you have alternatives if you want an in-line 2x4 system in an LA motor. Offenhauser had one, but it's a single plane with VERY short runners and I think this is the best bet for street car where there is much more lower RPM use than a race car.
