AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,974
- Reaction score
- 12,322
Were they even 020? That was a looong time ago. About 16 years now. Yeah probably they were.I threw the saucered ones away. They weren't all that way. IIRC I put cups on and another shim under that(I'm not real sure about the cups). The base shim I used was not 020;I was done with those.I cannot guess as to the total shimage in there, but I'm pretty sure there are 2 or more under every spring.(and I seem to remember buying some pretty fat boys, in addition to a kit of select fits) But ima guessing,cuz it was a long time.........
I think these were what I installed;
HUG 1110
VALVE SPRING SINGLE W/ DAMPER
120# @ 1.660" INSTALLED 310# @ .550" LIFT
Type of Spring:Single w/ damper
Installed Height/Pressure: 1.660"--120#
Pressure @ .450" lift: 280#
Pressure @ .500" lift: 300#
Pressure @ .550" lift: 310#
Coil Bind: .620" lift
Outer Spring ID/OD: 1.033"/1.440"
Not to many years ago .420 lift cams were mild;that's stock for '71 3602bbls IIRC. And if you were pushing .484 to.508 that was wild. Nowadays you can get deep into the .5xx, and still have streetable durations. Ain't it great!
HUG 1110
