PhillH
Hi,
had some issues that I thought were related to tuning my new 360, well I've pretty well got it worked out in no small part from help here. As part of the process I rebuilt the carb, the engine used to fire up immediately after hitting the key, then it took longer and longer cranking for it to start. I thought the fuel pump was going but, this is what I have discovered.
The engine now takes about 10 seconds of cranking, then a bunch of shots on the pedal, then another 10 seconds of cranking, then another bunch of shots on the pedal and it will start with no throttle. So I learned that the primary injectors have no fuel visually till all this cranking pumping, then once fuel starts to come out of the primary injectors it fires right up. It will fire up just reaching in and turning the key after all this. Then if it sits for 30 minutes or more I have to pump the fuel up again, same thing it will start fine after this.
Now I don't know where the fuel is going but it's definitely losing it's prime some where.
