scrappydoo
I would like to know if the springs on the edelbrock head will be ok for this cam
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=650&sb=2
Comp cams recommend the 995 valve spring which has a spring rate of 441 (they also recommend the 26995 beehives which have a rate of 280) and installed seat pressure of 130 and the edelbrock spring rate is 350lb/in and seat pressure of 125.
RPM limit will be 5500, I feel that the springs that are installed on the eddy heads will be ok.
Let fly with your expert opinions.
