[FOR SALE] Efi built 318/904/headers
SlantedDart
Michigan
Rating - 0%
0   0   0
Looking to sell entire engine and trans/ converter/ headers together. This engine is fresh only one summer of driving on it. I’m going gen three hemi so this has got to go. Very solid dependable combo.
Engine- 74 block .30 over (323)
- Holley terminator x efi throttle body good for 600hp. Comes with injector harness ONLY. No ECU or main harness. Keeping that for my swap. Can buy from Holley and will be direct plug and play.
- Holley billet duel sync distributor with wires. ( works with terminator)
- 360 heads new valve job/ valve seals/lifters/ springs.
- comp cam 270/270 512/512 on 109 lsa
- kb 167 zero deck pistons. Stock crank and rods.
- edelbrock single plane intake.
- entire new gasket kit
- comes with power steering/ 75 amp alt/ water pump/ pullies/ belts.
- engine mounts(slant six k member)(no pucks)
- msd street fire box and coil.
- no linkage or air cleaner
- will come with hoses if needed.
- no starter
- headers- 1-5/8 mild steel headers. Completely custom made. Double slip fit collectors for leak free seal. They all come apart for ease of install. Painted vht header paint and also wrapped in important areas.
trans- 904 completely gone through
- new steels clutch pack
- b and m street strip valve body
-hughes 3,600 stall converter. Doesn't not come with linkage or cooler lines. Have paperwork for about 80% of it
Complete engine with efi, throttle body, harness, msd box and coil-3,000$
Headers- 700$
904 with converter 1,500$
package deal 5,000$
pm for more information. Engine is still in the car running so you can hear it run! Located in Michigan will NOT ship. thanks!
