EFI for the Barracuda
jaws
I put the fun in dysfunctional
Strasburg Colorado
This is the victim, my 68 convert. 360 built to 68 340 4spd specs, and a 727. Going with the Fitech unit.
Awesome, I am doing the same EFI set up also! I used Aeromotive's in tank retrofit kit....but the new tank from Tanks Inc looks awesome!
Please continue to update. I am anxious to see how this works out. I am also considering EFI but I have some reservations about kinks
A little more done tonight after work.
got the tank plumbed and wired
got the old tank out, kicked my *** trying to get the filler tube out, stuck in big time.
put the TB on the intake
will need to modify the bracket for the cruise control hook ups.
Fitech is the direction I'd like to go when I get to that point. Which system are you using?
Going with the Professional Products EFI on the Wife's Road Runner. Powerjection III. Looks to be a good setup, we'll see. :)
Putting out other fires. Will work on it more today, Found the rear end leaking, and the harmonic balancer has slipped so need to fix that also. Where did you order yours form? Got mine from Pace performance, Johnny is a member here.
Got the rear end sealed back up, new gasket and 2 quarts of royal purple. Also got the tank in, not a fun job for one person. For some reason my camera dumped the pics.
Got the tank in and the pump and sender grounded. fuel lines run and a 10 micron filter on the sub frame connecter.
Lines hooked to the TB. and got the throttle cable and cruise control cable figured out. Can't do without my cruise
