BadAss71
Let's Go Brandon
This will be the second full swap I have done, and probably the most unique. I recently picked up this unbelievably straight and solid 57 Plaza, with this swap in mind. I had a line on a 99 Dakota R/T that a guy was parting out. I was able to get the motor, trans, dash, complete wiring and ecm, radiator, condenser, under dash HVAC unit, and everything else associated for a killer deal. The plan just fell together.
First off. The original 301 poly and 2 speed trans will move out, and make way for the more modern and usable 5.9 magnum and overdrive trans. The non a/c equipped car will now sport a complete and efficient a/c system. All of which will make this big girl much more enjoyable. All on a slim budget.
So far I have stripped the 5.9 motor and trans of wiring, swapped out the oil pan, and prepped the Plaza for the Magnum. The 301 will be excavating the premises tomorrow. Should hopefully have the 5.9 in its new home tomorrow afternoon. Here are a few pics from Today's fun!
