64dartbrian
I am wiring my electric choke on my 64 dart, i am thinking about wiring it into the wiper switch, I am just wondering if anyone else has a better place to wire it.
Type 'electric choke' into the search engine and you'll get your answer.I am wiring my electric choke on my 64 dart, i am thinking about wiring it into the wiper switch, I am just wondering if anyone else has a better place to wire it.
I agree, but make sure it is fused.The 12 volt side of the ballast resistor
I found a un-used fuse on my '64 Barracuda fuse block that was controlled by ignition switch.I am wiring my electric choke on my 64 dart, i am thinking about wiring it into the wiper switch, I am just wondering if anyone else has a better place to wire it.
Just what I said, Empty fuse controlled by ignition switch - hot with engine run.Any fuse "you found" was surely on the accessory side of the switch.......not what you really want for a choke
Only thing under the hood.....as said earlier^^ is the 12V side of the ballast.
FUSE it and consider using a relay. In fact consider using a relay to feed the choke, the VR, and the ignition power
Electrically speaking, you cut the blue "ignition run" wire coming out of the bulkhead connector, trigger a relay with the bulkhead end, hook the engine bay end to the output (contacts) of the relay, and run power to the relay through a fuse/ breaker off the starter relay "big stud." That leaves the relay ground. You could run that wire (if you want) to an "less - than - obvious" switch for a small measure of anti theft
Fuse block under the dash. My car had an open/unused fuse that was controlled by the ignition switch & was 12V with ignition on.I'd be interested to know what that is.......is it a stand alone/ add on or what?
